Activity Forums Adobe After Effects solid layers
  • Filip Vandueren
    September 7, 2005 at 11:54 am
    You can use the filter “Grow Bounds”
  • Dan Ebberts
    September 7, 2005 at 1:18 pm
    I think you can cut the masks (Edit > Cut), enlarge the layer, then paste the masks back in.
    Dan
  • Jeff Herring
    September 7, 2005 at 9:36 pm
    Can you create a new solid (solid #2) that has the bigger areas. then replace it with the origional solid.
    click on the layer you want to replace. goto your solids folder in your bin and while holding down ALT drag it onto the solid you want to replace in your time line. That should keep the effectes, transisionsm, and masks in place and just replace the material.
