Activity Forums Apple OS X Software Not Loading And Will Not Update
  • Software Not Loading And Will Not Update
    Posted by Patrick Morrow on December 16, 2005 at 3:20 am
    I have a e-mac that will not update software on line, it just fails 3/4 of the way through. It also will not load some software at time. Please advise.
    Thanks!!!
    Patrick Morrow
    Tony! Hulette replied 20 years, 9 months ago 2 Members · 1 Reply
  • Tony! Hulette
    December 16, 2005 at 4:12 am
    Not much to go on, but I’d say check to make sure your hard drive is no where close to full. Then startup off of the latest OS installer disk you have for it. Run Disk Utility to repair the startup drive and permissions. Remove anything plugged into you Mac while troubleshooting (printers, firewire drives, etc). Restart and try again.
    If not, try a “safe boot’ by holding down the shift key right after you hear the startup chime (you can let go when the little gear icons starts spinning). After it boots try to update again.
    If that doesn’t work, boot from the installer disc again and try and archive and install of the OS. Be sure to choose the options to save your files, applications and networks settings. After the install, repair the permissions and drive again, then use the Apple software update to get you up to the latest versions. When its all done, repair the permissions and drive one last time.
    Tony!
