Activity › Forums › Adobe After Effects › soften edges
  • soften edges
    Posted by Dotan Baytman on December 6, 2006 at 9:58 am
    i have a rectengular banner and i need to make it less rectengular
    meaning to soften the edges a little something like the rounded rectebgular in photoshop
    masks doesnt look good enough any ideas?
    Dotan Baytman replied 19 years, 9 months ago 5 Members · 5 Replies
  • Joshua Ferg
    December 6, 2006 at 11:45 am
    Try duplicating the layer a few times, scaling up or down sizes and blurring to taste.
  • Mylenium
    December 6, 2006 at 2:57 pm
    Copy & Paste a rounded corner rectangle (aka bullnose mask) from Photoshop to AE as a mask, then use feathering on the mask shape.
    Mylenium
    [Pour Myl
  • Alexander Gao
    December 6, 2006 at 2:58 pm
    Why don’t masks look good enough? I would think it would work very well, if you made a rectangular mask a little smaller than your banner and then just feathered the edges a little bit… no?
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
  • Iancorey
    December 6, 2006 at 7:02 pm
    Two options.
    Place the image in a comp, double click the mask tool. Twirl out the mask settings and set the Mask Expansion to negative.
    OR
    Use Simple Choker in Effects > Matte.
    Hope it works!
    ian
  • Dotan Baytman
    December 6, 2006 at 10:05 pm
    Thanx guys the negative expansion and feathering works fine
    can you explain the matte choker part?
