Activity Forums Apple Final Cut Pro Legacy soft wipe renders w hard edge
  • soft wipe renders w hard edge
    Posted by Bob Flood on April 18, 2006 at 5:12 pm
    Hey everybody
    I am using the gradient wipe to transition from one shot to the next right to left, no gradient, softness at 98, inverted (so it goes right to left)
    when i add it and preview it it looks fine, but when i render it i get this hard edge on the back, as if its only soft on the leading edge of the wipe? what gives? any ideas or comments?
    os 10.4.3. dual 2.7. fcp 5.0.4 sequence at 8 bit SD
    bee eph
    Bob Flood
    Greer & Associates, Inc.
    Robert Garry replied 20 years, 5 months ago 3 Members · 2 Replies
  • David Roth weiss
    April 18, 2006 at 5:29 pm
    Bob,
    Try putting a black slug on a layer below and see if that helps… Just a guess, but see if it works.
    DRW
  • Robert Garry
    April 18, 2006 at 7:32 pm
    Make sure to render at the highest possible setting. If you are using a realtime render (meaning you have a colored bar above the transition) FCP may not be showing the entire effect but dumbs down to what it can play in realtime. This is common in certian situations and a change of render settings usually fixes it.
    Good Luck
    Bob
