Activity Forums Maxon Cinema 4D soft body and moText ???
  • soft body and moText ???
    Posted by Taras Kosmachuk on December 20, 2010 at 12:32 am
    Hi. I’m new to cinema 4d and I need help.
    I want to apply soft body to moText but when I do that and play the animation text just fall by pieces (caps end extruded edge), haw do I make text a solid soft body object so it’s didn’t fall apart??? I’m using C4D R12.
    Taras Kosmachuk replied 15 years, 7 months ago 2 Members · 4 Replies
  • Brian Jones
    December 20, 2010 at 4:31 am
    I think you would have to connect the parts, either make it editable, select the bits (caps, extrude) Functions/Connect and Optimize or put the MoText in a Connect Object and apply the Soft Body to that.
  • Taras Kosmachuk
    December 20, 2010 at 9:24 am
    Thanks Brian!
    Connect and Optimize working fine, but is there a way to keep text editable (Connect Object not working)
  • Brian Jones
    December 20, 2010 at 2:51 pm
    it was working for me last night but you have to attach the soft body tag to the Connect Object not to the MoGraph text
  • Taras Kosmachuk
    December 21, 2010 at 1:13 am
    ok, thanks again!
