Activity › Forums › VEGAS Pro › So Tired of Vegas Crashing Constantly
  • So Tired of Vegas Crashing Constantly
    Posted by Ken Matson on September 25, 2012 at 7:53 pm
    Hi – I’m on Vegas 11 64B working on I7 2600 8 core with 16G – just installed the latest Vegas patch, but this was going on before.
    Problem: Vegas crashes on me about every 7-10 minutes of working. Just stops and the little window comes up that indicates a crash saying reason not determined and asks if I want to send a report.
    There’s no one project, effect, action, process, or anything that I can determine that causes this. Seems to happen most often, but not always, when I start playback after doing something – but also when rendering, working with a FX, or doing most anything. Sometimes it seems to crash every few minutes … sometimes I can go 20-30 minutes and it works fine.
    It doesn’t seem to be related to the complexity of a project or wht I;m doing anything. I turned off autosave at one point, and that seemed to help some. Also – saving often manually seems to help. These days I save about every 2-3 actions, which makes it at least possible to work after it crashes … but often if I forget to save for a bit … a crash will happen.
    Don’t seem to have any other issues with computer, though 90% of what I do with it is Vegas.
    Question: Are there any settings I ought to be looking at here? This seems to have gotten worse in last couple months, though I can’t trace it to any “Event” that happened. Any other thoughts?
    TIA!
    KenM
    Sound Works R&P
    Ken Matson replied 13 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Jim Greene
    September 25, 2012 at 9:08 pm
    The most common problem is in the Preferences, the “Video” tab, set the “Dynamic RAM Preview max” to 0. By default this has some value and lots of crashes go away when set to 0.
    -Jim.
  • Ken Matson
    September 25, 2012 at 10:15 pm
    Ughhhhh …. I use dynamic RAM preview all the time … not sure how I’d live without it …..
    KenM
    Sound Works R&P
  • Jeff Schroeder
    September 25, 2012 at 11:04 pm
    Check out the latest update. Some guys are getting good results. Please post here if it helps you.
    https://forums.creativecow.net/thread/24/953886
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • John Bolton
    September 26, 2012 at 7:31 am
    Hi Ken, have you tried it with the the GPU option un-ticked?
  • Ken Matson
    September 26, 2012 at 5:30 pm
    Hi Jeff – no – I had already installed update – no better – thanks!
    Ken
    KenM
    Sound Works R&P
  • Ken Matson
    September 26, 2012 at 5:32 pm
    Yep -it’s already off. Thanks for idea!
    KenM
    Sound Works R&P
  • Harry Maathuis
    September 28, 2012 at 3:36 pm
    Hi Ken,
    Very recognizable, if not exactly the same. Problems started with VP11. I have the same problems on another PC that is substantially identical. I tried everything, including: clean boot, BIOS settings, compatibility mode (Run setting), reinstall, disabling (all) codecs etc..
    System specifications:
    – Motherboard: Gigabyte EX58-Extreme
    – CPU: i7-920
    – Memory 12GB
    – Video card: HD5750 (Catalyst 12.8)
    – Windows 7 64 bit
    I intend to try it with a complete new system setup, but I look up against the effort it will take.
    B.t.w what are your system specifications?
    Harry Maathuis
  • Ken Matson
    September 29, 2012 at 2:02 pm
    Hi – Vegas Pro 64 – latest build (from the other day – but problem long before that and continues)
    Intel Core 7 2600 3.4G 8 Core (4 phys / 8 log)
    16G RAM
    NVIDIA Geoforce GTX500
    2 2TB SATA Drives
    KenM
    Sound Works R&P
  • Ken Matson
    October 10, 2012 at 10:34 pm
    Thought I’d give an update on this one. I tired several things, but lowering my RAM for Dynamic RAM Preview seems to really have helped a lot. I changed it from 2048 down to 1500. I didn’t think 2048 would be a problem with 16G total, but either it’s a big coincidence or that made the difference. It has not totally cured the problem, but far fewer crashes.
    KenM
    Sound Works R&P
