Activity › Forums › Adobe After Effects › So simple but making a mask or shape into motion path
Posted by Gchatt on October 22, 2007 at 7:58 pmHello
Just beginning in this is excuciating simple,
but I need to rotate an object (which is no problem) whilst its position moves around in a circle. I can not seem to make a shape or a mask into a motion path?
Please can anyone help?Tom Nelson replied 18 years, 11 months ago 3 Members · 4 Replies -
Todd Kopriva
October 22, 2007 at 8:50 pmDave’s instructions are good. If you want more information, see the “Create a motion path from a mask, shape, or paint path” section of After Effects Help.
If the Help document doesn’t contain the information that you need, or if you’d like to add a tip of your own, leave a comment using the link at the bottom of any Help page.
Todd Kopriva, technical editor, Adobe Systems Incorporated
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
How about taking a survey about After Effects documentation? Please?
Tom Nelson
October 23, 2007 at 6:31 pmI’ve got to admit – AE’s User Guide and help menu incorrectly or at least inadequately cover this – they both say you can copy the mask, they don’t point out that you need to highlight the mask shape property in order to paste it. Makes a big difference.
Tom Nelson
Videographer/Editor
Essex Television Group -
Todd Kopriva
October 23, 2007 at 8:03 pm[Nelson] “I’ve got to admit – AE’s User Guide and help menu incorrectly or at least inadequately cover this – they both say you can copy the mask, they don’t point out that you need to highlight the mask shape property in order to paste it.”
Step 1 of the procedure in the “Create a motion path from a mask, shape, or paint path” section of After Effects CS3 Help says this:
“Select a Path property in the Timeline panel, and choose Edit > Copy.”
Is that not explicit enough? If you have a suggestion for how to improve Help, please add a comment by clicking the Add Comment button at the bottom of the page of Help on the Web.
Tom Nelson
October 23, 2007 at 8:18 pmI stand corrected, Todd. The help file for AE is much more complete than the paper user guide, which simply says to “Select a mask” and then “copy the mask to the clipboard.” Simply following these directions and copying the actual mask doesn’t work. I guess I’ll stick to the help file from now on.
Tom Nelson
Videographer/Editor
