Activity › Forums › Apple Final Cut Pro Legacy › Snow Leopard Incompatibility With Many eSATA Cards
Posted by Zane Barker on August 29, 2009 at 7:59 pmTo anyone planing on moving to Snow Leopard if you are using a eSata card you need to check to see if it is compatible.
Any eSATA card that uses Silicon Image SiI3132 Drivers is not compatible and will cause kernal panics.
https://support.apple.com/kb/HT3258Sadly the the majority of eSata Express cards use that driver.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity!Gabriele Pellegrini replied 13 years, 7 months ago 33 Members · 64 Replies -
David Roth weiss
August 29, 2009 at 8:04 pm[Zane Barker] “Any eSATA card that uses Silicon Image SiI3132 Drivers is not compatible and will cause kernal panics.
“And, for good reason that can and will cause user panic.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Gary Adcock
August 29, 2009 at 8:17 pm[David Roth Weiss] “And, for good reason that can and will cause user panic. “
actually not…
funny I posted this on a related topic, but during the installation process with Snow Leorpard the incompatible files are moved into a separate labeled folder to keep some of that panic to a minimum.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
David Roth weiss
August 29, 2009 at 8:32 pm[gary adcock] “during the installation process with Snow Leorpard the incompatible files are moved into a separate labeled folder to keep some of that panic to a minimum. “
What does this do however in terms of making a raid function properly?
Also, that link seems to have gone to link heaven. What happened?
David Roth Weiss
Director/Editor
Zane Barker
August 29, 2009 at 8:33 pmthe incompatible software thing only comes up i believe if you fun Snow Leopard as an upgrade, not as a clean install like i did.
eSata cards that use the JMicron chip seem to be time and actually require no drivers at all as they are natively supported by the OS.
I have a JMicron chip card only issue is it only has 1 eSata port not 2 like my Griffin card that uses the now bad drivers.
Don’t let technology get in the way of your creativity! -
Patrick Jones
August 29, 2009 at 8:55 pmno issues with my Sonnett ExpressCard eSata card. I did have to re-install the driver.
FCS 3 – MBP 2.93ghz 4gb RAM, 300gb 7200 Internal HDD, iStarUSA Dual Dock with (10) 1TB 3.5 Seagate Barracuda drives, and a couple 250’s Maxtors, and Seagates.
James Iles
August 30, 2009 at 3:51 amCan anyone confirm that the eSata cards that come with the Matrox MX02 work okay? (Am hoping to purchase an MX02 soon). Thanks.
Andy Mees
August 30, 2009 at 4:58 am[James Iles] “Can anyone confirm that the eSata cards that come with the Matrox MX02 work okay?”
James, the Matrox MXO2 comes with an ExpressCard/34 based PCIe adaptor … its not an eSATA card. (It works fine but please bear in mind that it is not officially supported until Matrox release SL specific drivers).
Best
Andy -
Gary Adcock
August 30, 2009 at 2:36 pm[David Roth Weiss] “Also, that link seems to have gone to link heaven. What happened? “
Works in Safari on Snow- I checked it to make sure
works on this page—- https://forums.creativecow.net/readpost/8/1051091
[David Roth Weiss] “What does this do however in terms of making a raid function properly? “
Well that would be a different story-since without connection to the RAID you do not have one, but it should not have affected anything stored on that RAID volume.
gary adcock
Studio37
Cory Caplan
August 30, 2009 at 4:00 pmThanks for this. I was about an hour from going to the Apple store to pick up SL. Considering my startech eSata dock is my new beloved part of my workflow, this would have been a bad, bad thing. (Firmtek S2e2 here…)
