Activity › Forums › Apple Final Cut Pro Legacy › Snow Leopard Incompatibility With Many eSATA Cards
Gabriele Pellegrini replied 13 years, 7 months ago 33 Members · 64 Replies
Rafael Amador
July 27, 2011 at 9:12 pm[steve knattress] “Now apple really are trying to screw professional editors!!!”
Professional editors do not update a system without thinking on those little details before.
This is not Apple’s fault.
I guess the Silicon driver is not the only software that will need update. Lion has just been released and manufacturers needs time to make the changes.
rafael -
Tad Newberry
September 30, 2011 at 9:31 pmi had read this thread AFTER getting a LaCie card today. it is working fine after installing the driver from the CD. no kernel issues…yet.
thanks for helping out a bonehead!
__________________________FCS3
2.66 GHz Quad-Core Mac Pro
6GB RAM
NVIDIA GeForce GT 120
…and a few TeraBytes o’ storage
(then it’s on to PetaBytes, ExaBytes and MosquitoBytes!) -
Gabriele Pellegrini
April 12, 2012 at 4:31 amI am using a LaCie SATA II PCI Express Card Professional 4 doors on a MacPro dual 6-core processor running under OsX Lion with Avid Nitris and Media Composer 6.01. Card Act ExpressSAS R380 connected to an Avid video raid SR 5TB in RAID1 “even if I turn it into raid 0” my problem is that virtually any driver lacie trying in circulation does not work. And I have 2 lacie quadra from 4TB and 6TB of one and not feel like I’m And I have 2 lacie quadra from 4TB and 6TB of one and I will not use the FireWire800 presioni’m doing to support the lacie to compile a driver for mac OSX LION.now then that will come out new version of OsX telling him so well that I have problems lose their customers clearly I’d be right on OsX Lion ……. cards are inserted into the slot so 1GPU in slot 2 slot 3 to the Act lacie and 4 of the card Nitris.
Do you have any advice for me I tried to install by opening the package instalation of the driver alone that is successful for under the system tells me that it lacks the drivers for the raid controler and I doubt that is the face of conflict with the ACT lacie but I can not do experiments that I have seen work and above all with the Lacie I have always found it well because I have replaced a BigestS2 a month after the end of the guarantee with a Quadra 6TB by interpraise ……..
Do you have any advice for me you are my lastSorri my bad English
Best regards
Gabriele Pellegrini Switzerland -
Gabriele Pellegrini
February 2, 2013 at 2:20 amI found the solution.
In MacPro I have inside is also a ATTO R380 card the first connection for HD Avid MC and I put in the second multiplier to 8 SAS ports eSata I connected my two 4big Quadra Raid and work perfectly. It ‘a solution that I’ve adotato long I apologize for not having given my first solution maybe now the driver for the boards eSata that several people have made a fool now works but I personally have not watched more and the card removed from the MacPro and put a Quadro 4000 in its place. I hope for you that finally the driver and the year written works ……….
Best Regards
Gabriele Pellegrini
