Activity › Forums › Apple Final Cut Pro Legacy › Snow Leopard Bugs???
  • Snow Leopard Bugs???
    Posted by Nate Stephens on August 3, 2010 at 2:07 am
    Hey guys,
    I have been using Snow Leopard since January and even did a clean install of everything 90 days ago.
    It has been working fine till this morning and now it will not boot in Snow Leopard. It boots in Leopard and runs fine. The Snow Leopard hard drive even shows up when booted in Leopard and works fine. I Carbon Copied Snow Leopard to a firewire drive that shows up as a bootable drive but will not boot.
    I have done nothin, no new installs, no upgrades that I can remember, that would prompt it not to boot.
    Is there a Snow Leopard virus going around?
    Does this mean that I have to re-install everything or does Snow Leopard install disc have a fix-it program?
    Any ideas besides the dreaded re-install everything two day marathon?
    thanks
    FCP, Mac Pro, Mac Book Pro, HPX500, HVX200, Betacam, Dvcam
    Write for the Edit, Shoot for the Edit, Edit…..KISS Principle
    Nate Stephens replied 16 years, 2 months ago 4 Members · 10 Replies
  • 10 Replies
  • Steve Eisen
    August 3, 2010 at 2:58 am
    How is that Firewire Drive Formated? What is the Partition Map Scheme?
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Zane Barker
    August 3, 2010 at 3:07 am
    Run disk warrior on the drive.
    **Hindsight is always 1080p**
  • Nate Stephens
    August 3, 2010 at 5:14 am
    I did run disk warrior and the firewire drive is extended-formated. not journaled.
  • Steve Eisen
    August 3, 2010 at 11:23 am
    Steve Eisen
    Vice President
  • Nate Stephens
    August 3, 2010 at 12:43 pm
    Steve, I did not partition the drive. It is a 500gb IDE drive that I installed in the spare optical bay.
  • Paul Dickin
    August 3, 2010 at 1:12 pm
    [Nate Stephens] I Carbon Copied Snow Leopard to a firewire drive that shows up as a bootable drive but will not boot….
    Hi
    If its an IDE drive the likelihood is that when it was originally initialised it had an Apple Partition Map installed.
    An Intel Mac won’t boot from that Boot-partition scheme – Intel Macs need a GUID Partition Map.
    So before you CCC’d the data from your original boot drive you should have repartitioned the FW drive with GUID (in the Custom options).
    [Nate Stephens]
    “KISS Principle”
    That means setting it up “GUID to go”!
  • Zane Barker
    August 3, 2010 at 1:30 pm
    “If its an IDE drive the likelihood is that when it was originally initialised it had an Apple Partition Map installed.
    An Intel Mac won’t boot from that Boot-partition scheme – Intel Macs need a GUID Partition Map.”
    NOT TRUE. I was actualy just talking about this the other day with a buddy who works as a Genius in a Apple Store. He tells me you can and in fact the external drives they use to boot computers off of are mostly partitioned using Apple Partition map. He says they do that so that they can use the external bootable drive with any machine (they have boot partitions on there clear back to 10.4). He told me a PPP machine cannot boot from a GUID partition but a Intel most defy nitty can boot from a Apple Partition Map drive.
    He did say that it is recommended to have the drive partitioned GUID for your main system drive but it does not have to be.
  • Paul Dickin
    August 3, 2010 at 2:37 pm
    Hi
    Silly me – there was me believing Apple’s documentation 😉
    “To install Mac OS X on the disk, you must partition the drive to match the native partition scheme for your computer’s processor type (Intel or PowerPC).
    https://support.apple.com/kb/ts1600
  • Nate Stephens
    August 3, 2010 at 5:19 pm
    This is all good to know and means I need to do some research to get the firewire drive to act as a boot drive.
    But it does not explain or help me decipher the original problem with the internal Snow Leopard boot drive. That had been working great until yesterday, when the machine refused to boot from it.
    If you hold down the option key when powering up, the Mac sees it, just wont boot from it.
  • Nate Stephens
    August 4, 2010 at 6:54 am
    Don’t ask me why after 6 months of working fine the IDE boot drive in the spare optical bay decided not to boot. It was never partitioned, just 500gbs big.
    But it did fail to boot. So I restarted in Leopard (on another HD) and the Snow Leopard drive was still there, I Carbon Copied it this time to a GUID partitioned firewire drive and dang the firewire drive booted in Snow Leopard just fine. So back to leopard I went and did the GUID partition on the original Snow leopard IDE hard drive and then Carbon Copied the firewire SL boot drive back to were it belongs and double dang, you guys are magicians cause now the machine is working just like it was last week.
    And I didn’t have to open all those software packages and load each program and all their damn serial numbers… So triple thank you….. even tho there are rumors that you don’t need to Guid your IDE, it worked for me..
    Thanks again..
