Activity Forums Adobe Premiere Pro Snapping when dragging keyframes
  • Snapping when dragging keyframes
    Posted by Brian Sarfatty on October 17, 2012 at 4:18 am
    When I’m dragging audio keyframes left/right, is there any way to lock or snap them so the volume doesn’t change, just the time position?
    Tried holding down all modifier keys, and turning master snap on and off. No luck 🙁 super annoying.
    Brian Sarfatty replied 13 years, 10 months ago 2 Members · 2 Replies
  • Gabriel Sanchez
    October 17, 2012 at 10:11 am
    Yes, it´s very annoying, actually the best way i found to control it is dragging keyframes in the effects pannel timeline instead of the yellow line in the clip, as you can see the keyframe volume level reference in numbers and fix tiny changes manually if needed.
    Regards
  • Brian Sarfatty
    October 17, 2012 at 1:41 pm
    Ahh. Good work around. Much easier to move keyframes there and not affect volume.
    There are so many things I love about Premeire, but there’s a good two handfuls of really basic things they overlooked.
