Activity › Forums › Adobe Premiere Pro › snapping video when moving it up or down layers
  • snapping video when moving it up or down layers
    Posted by Michael Duff on December 9, 2012 at 7:48 pm
    Hi again with another FCP->PP user question …
    I want to move a number of clips to the track below where they currently are. I want to be able to do it quickly, and with it locked so that the clips don’t nudge left or right. In FCP I’d just hold shift I think while I dragged them down… or used the keyboard shortcut. I realise from other posts there is no keyboard shortcut to move clips up or down layers.. but my question is, is there a way to make it snap so that the clips don’t move in time. With normal snap, the clips sometimes snap to another clip a few frames away.
    Jeff Friah replied 11 years ago 5 Members · 4 Replies
  • Trevor Ward
    December 19, 2012 at 3:41 pm
    Seems to me you just have to select the clip in the timeline and drag it down or up. As long as snapping is on, it stays in position.
    -Trevor Ward
    Red Eye Film Co.
    http://www.redeyefilmco.com
    Orlando, FL
  • Darren Solomon
    February 1, 2013 at 2:30 am
    Could you not move the current time indicator to the beginning of the clip (page up/ page down) and then drag it down? It may not be as fast as a keyboard shortcut, but I have found that to work really well for me.
    Darren
  • Owen Tooth
    September 11, 2015 at 2:24 pm
    To add to this very old post, what you need is the ‘Nudge clip selection up’ and ‘nudge clip selection down’ command. On PC, the standard shortcut is alt-up arrow or alt-down arrow. If you open keyboard shortcuts you can search for nudge to see what the shortcut is on whichever system you are using.
  • Jeff Friah
    September 11, 2015 at 3:06 pm
    This has ‘bugged’ me as well – I can grab regions/clips and move them to another track and there is displayed on the screen a ‘time adjustment amount’ which should read 00:00:00:00 if you’re actually in-line with where you’re moving it from. In a popular audio editing software package I’m familiar with, we can hold down Cmd- while we drag and that clip is LOCKED to time, so even the slightest sideways movement of the mouse will not time-adjust. Doesn’t seem you can do that ‘quickly’ in Premiere and I find myself putting way too much time into moving things from track to track worried about shifting time sync.
    YES it does appear that (mac) Opt-up / down arrows will move clips accordingly. Keyboard shortcut that of course can be customized.
    Jeff
    “Sounds good!….I think?”
