Activity Forums Apple Final Cut Pro Legacy smothcam fxplug limitation in “academic” versions?
  • smothcam fxplug limitation in “academic” versions?
    Posted by Sparkyflint on August 31, 2007 at 2:28 pm
    Does anyone know if there is a limitation of the fxplugs in the academic versions of FCP?
    I’ve installed and uninstalled twice.
    Reparied permissions to drive.
    there was not even a plug-in folder at the root until I installed FxFactory trial pack. Now that folder is present, but that’s all there is in there.
    The smoothcam filter(and several others) are “bold” in the browser, and when I go to it’s properties it says that there is no script attached, or something to that effect.
    Help?
    Sparkyflint replied 19 years ago 2 Members · 2 Replies
  • Jeremy Garchow
    August 31, 2007 at 3:49 pm
    I don’t know if there are limitations, but FCPs native fxplug filters are not installed in the fxplug folder. That’s for 3rd parties. Make sure you go to Effects > Effect Availability > All Effects.
    Jeremy
  • Sparkyflint
    August 31, 2007 at 6:46 pm
    thanks, but that didn’t fix it.
    simple case of RTFM.
    i was trying to use it on a .dv clip, and it only works on QT.
    live and learn.
