Activity Forums Maxon Cinema 4D Smoother vectors?
  • Smoother vectors?
    Posted by Kelly Johnson on July 26, 2006 at 7:53 pm
    Hello-
    I’ve set some lettering within C4D (v8) and extruded them. I then selected the text spline and the extrusion nurb and chose “Current State to Object.”
    However, when I check the render, the spline at the curves are not real smooth. I tried, for grins, throwing that into a hyper-nurbs but it rounds everything too much and I lose some neat shadow caused by selecting the “Engraved” caps option.
    I guess I’m wondering if there is an equivalent for text splines such as adding more segments to a sphere object to smoothen the profile.
    Kelly Johnson replied 20 years, 2 months ago 1 Member · 1 Reply
  • Kelly Johnson
    July 26, 2006 at 7:57 pm
    Well, I just found that I could select the text spline and choose Intermediate points to be ‘Adaptive’ and then choose 0 percent for the angle and that helped.
    Unless there’s something else, I’m good with that..kj
