Activity › Forums › Apple Final Cut Pro Legacy › SmoothCam vs Motion>>Stabilize vs Shake>>SmoothCam
  • SmoothCam vs Motion>>Stabilize vs Shake>>SmoothCam
    Posted by Bob Roberts on July 2, 2007 at 7:21 pm
    Has anyone actually gone through a full “analyze” in FCP’s SmoothCam? I started a 5 second clip and it said 2 hours just to analyze the clip. Are there some advanced settings to make it go faster?
    On the other hand, I sent the same clip to Motion and used the Stabilize feature and got the results I expected render time/quality-wise.
    If you’re geeky enough to work with Shake, I still think it delivers the best value in terms of render time/quality with its additional anti-motion blur capabilities.
    Thoughts?
    Flavio G. garcía replied 19 years, 2 months ago 3 Members · 2 Replies
  • John Pale
    July 2, 2007 at 7:34 pm
    Smoothcam within FCP analyzed the full media file, not just the clip in/out. If its a long file, it will take forever. The solution, according to the manual is to Export the necessary section as a Quicktime then re-import, before running Smoothcam on it.
  • Flavio G. garcía
    July 2, 2007 at 8:47 pm
    I
