Activity › Forums › Apple Final Cut Pro Legacy › Smoothcam preview OK but not render
  • Smoothcam preview OK but not render
    Posted by Ken Pugh on March 30, 2011 at 10:07 am
    I’ve seen many posts on this – but not a solution as yet.
    I’m using smoothcam on a short clip, it works fine in preview after the analysis has been done (ie with a green line above the clip in the timeline) but as soon as I render it goes back into shaky mode. Not as shaky as the original file, but not nearly as super smooth as the preview. I’m working in a HD ProRes timeline with HD ProRes clips upper field interlaced 50i. FCP7.
    Tried dropping a field to emulate the preview mode, but this doesn’t work.
    A workaround would be to export the file in preview mode (without rendering) and re-import – but assume this is not logically possible?
    Best,
    Ken.
    Ken Pugh replied 15 years, 4 months ago 4 Members · 5 Replies
  • Paul Jay
    March 30, 2011 at 12:25 pm
    It’s a 7.03 bug for interlaced footage.
    Progressive footage doesn’t have this problem.
    Use Motion instead.
  • Ken Pugh
    March 30, 2011 at 5:47 pm
    Thanks, that worked really well.
    Ken.
  • Nicholas Treharne
    May 16, 2011 at 11:18 am
    I have the same problem. What are the steps to fix in motion??
  • Andy Mees
    May 16, 2011 at 12:15 pm
    Try adding the Shift Fields filter in FCP (Effects > Video Filters > Video > Shift Fields)
  • Ken Pugh
    May 16, 2011 at 12:19 pm
    Export the clip from FCP (right click then ‘send to’ ‘Motion’)
    In Motion choose Behaviours / Motion Tracking / Stabilise – apply
    In HUD change Method to smooth
    change Borders to zoom
    change adjust to select Position scale and rotation
    Analyze and Save
    Go to FCP and render – I had fantastic results.
    Ken.
