Activity › Forums › Maxon Cinema 4D › smooth wireframe
  • smooth wireframe
    Posted by Peeter Wintzaouer on February 15, 2009 at 4:50 pm
    for a job i need to do a sphere in wireframe.
    I founded a lot of tutorials who explain how to do a Wireframe render, Cel render, atam aray, …
    i think my solution will be to use the atom aray because i don’t want to have an flat wireframe. I need some volume in the edge.
    BUT, i also need to have a smooth sphere with not to much edge.
    For exemple i need to do a sphere of a radius of 100 but with only 15 segments. When i set this settings my sphere is not smooth anymore. Of course because to have a smooth sphere or object i need a lot of segment
    So how can i have a smooth sphere with few segments (in the wireframe render) ?
    Thanks a lot
    B
    Nolan Scott replied 17 years, 7 months ago 2 Members · 1 Reply
  • Nolan Scott
    February 16, 2009 at 5:09 am
    Create a Sphere and select all the Edges / Structure / Edit Spline / Edge to Spline…
    Select all the Points of the new Sphere.Spline / Structure / Edit Spline / Soft Interpolation…
    (that should smooth out the sharp edges)
    Create a Circle-Spline (Radius about 1 m or 2 m) drag both –
    the Circle-Spline and the Sphere.Spline – into a Sweep NURBS…
    (maybe delete the original Sphere if you like)
    Cheers
    Nolan
