Activity › Forums › Adobe Premiere Pro › Smooth then erratic playback
  • Smooth then erratic playback
    Posted by Scott George on January 18, 2010 at 1:00 am
    THE CLIP PLAYS SMOOTH…BUT SOMETIMES WHEN PLACED IN TIMELINE THE TIMELINE DOES NOT PLAY SMOOTH ITS KINDA HERKY JERKY
    THIS IS BOTH ON CS3 AND ON CS4 ANY IDEA WHAT MIGHT CAUSE THIS ???
    Brian Louis replied 16 years, 8 months ago 2 Members · 3 Replies
  • Brian Louis
    January 18, 2010 at 1:12 pm
    Usually it can mean limited resources, particularly with highly compressed footage, what is the type of footage and what are your computer specs?
    BTW, your caps lock maybe on, all caps mean shouting on the net.
  • Scott George
    January 18, 2010 at 1:59 pm
    First thanks for your reply
    The footage was shot on dvx100 at 24 fps , i have done some other stuff just tinkering and they were fine.I will need to check specs on computers they are both out of the box with no modifications and single hard drives , desktop and laptop both run vista ?
    Many thanks,
    Scott
  • Brian Louis
    January 18, 2010 at 6:12 pm
    [Scott George] “single hard drives”
    Single hard drives can give you grief, you should have a separate drive for video files, with DV a external USB 2.0 harddrive usually will suffice unless you have a bunch of USB devices connected.
