Activity › Forums › Adobe Premiere Pro › Smooth dissolves in premiere 2014?
Posted by Joel Arvidsson on June 25, 2014 at 10:45 amI had problems with dissolves and premire for years and went to after effect alot. But previous version adobe fixed this. But now in 2014 i think we are back again.
Just wanted to se if more is experience this?
Dennis Radeke replied 12 years, 2 months ago 3 Members · 5 Replies -
Dennis Radeke
June 25, 2014 at 12:58 pmHi Joel,
A little more detail on what you’re describing, how to reproduce it, what kind of system your on, what’s wrong with it, etc. would be very helpful. From there, perhaps we can figure out what the issue is.
Many thanks,
Dennis – Adobe guy -
Richard Knight
June 25, 2014 at 5:08 pmTry unchecking ‘Composite in Linear colour’ In the sequence settings
Joel Arvidsson
June 25, 2014 at 6:36 pmThe problem is that the disolve happens to fast. The actuall disolve is done after 20% of the total span of the effect.
It was a big problem before but previos version worked good.Im running a supermicro with dual 2687w with 64g ram and a nvidia gtx690 on windows 8 proffesional. Os on ssd and media on fast raid.
It worked in previos version.
Joel Arvidsson
June 25, 2014 at 6:38 pmI will try to uncheck it tomorrow. But I think i tried this in earlier versions i had this problem in and it gives other side effects.
Dennis Radeke
June 27, 2014 at 1:19 pmBeyond the linear color, you can try updating your graphics drivers, disabling and GPU acceleration and try the film dissolve to see if it gives you an aesthetic you’re looking for. If turning off the GPU fixes the issue, then definitely report it through the Adobe site.
