Activity › Forums › Adobe After Effects › Smoke Stream, another
  • Michael Szalapski
    December 24, 2009 at 4:17 am
    I’m saying you could achieve this several different ways.
    You could certainly do it with several layers of particle effects. Just keyframe the emitter to point up and down with wind or gravity set to go to the right.
    Or alternatively, you could do it this way.
    You could do it with a displacement map following some of the techniques in this old tutorial.
    Or you could toy with this series of old tutorials. Part one, part 2, part 3
    To be honest, you could even do that with several solids at partial opacity with animated, feathered masks.
    I’m sure others could think of even more ways.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Vincent Rosati
    December 24, 2009 at 4:02 pm
    Thanks for pointing me in the right direction! 🙂
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Michael Szalapski
    December 24, 2009 at 7:17 pm
    One of these ways will get you there eventually…
    – The Great Szalam
