Smart Rendering MPG2 problem
I’m experiencing problems when smartrendering MPG2 files in Vegas 8 and 9.
I’ve matched the compression settings in the Mainconcept plugin (GOP length, bitrate, etc), so the ‘No recompression required’ message appears.
Nonetheless, when I use transitions and fades, the image ‘jumps’ back a few frames on the points where the re-rendered parts meet the unrendered parts.
I’ve played around with every setting in the Mainconcept plugin, but I did not succeed in finding a solution.
Some technical details: the source material originates from a Sony DCR-SR37E Harddisk camcorder. Analyses of the files learned that the nominal bitrate is 9.100.000 bps, with a gop length of 12, and 2 b frames.
Can someone please help me?
Thanks in advance,
Igo Nijenhuis
The Netherlands.
