Activity › Forums › Adobe After Effects › Smaller resolution
  • Smaller resolution
    Posted by Hermann Haf on July 23, 2012 at 12:32 am
    Hello
    Im trying to make a video 5×28 in AE but the program automatically resizes it to 16×28, is 16×16 the minimum?
    Is there no way to make it 5 pixels high?
    And yes I know its a really small video, its for a pixel art video on a building.
    Hermann Haf replied 14 years, 2 months ago 6 Members · 10 Replies
  • 10 Replies
  • Darby Edelen
    July 23, 2012 at 4:00 am
    Well, I checked in CS5 and CS6 and the smallest resolution available in both of those is 4×4.
    What version are you using?
    Darby Edelen
  • Angelo Lorenzo
    July 23, 2012 at 6:25 am
    Hm, lets me do it in CS6 and CS5.5 without an issue. Do you have “lock aspect ratio” unchecked?
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Hermann Haf
    July 23, 2012 at 12:11 pm
    Hey guys
    Im using CS5
    Im new in AE so I guess im doing something wrong.
    Here’s the setting im using when I make a new file:
    And this is what I get when I save as a movie from the render output settings:
    Im saving the movie as a quicktime movie.
  • Juan Manuel
    July 23, 2012 at 1:22 pm
    Most, if not all, lossy compression codecs require the frame size to be divisible by 4, due the way they work. I don’t know off the top of my head if there is a codec which will allow you to export a frame size that’s 5 pixels horizontally, but you could try uncompressed formats like animation. Note that this maybe a issue for final delivery, depending exactly in what you’re going to do with the animation.
  • Darby Edelen
    July 23, 2012 at 2:06 pm
    Indeed, this is not a limitation of AE but a limitation of the codec you’ve chosen in the output module.
    Darby Edelen
  • Hermann Haf
    July 23, 2012 at 2:28 pm
    can you guys recommend any other codec I can use ?
  • Walter Soyka
    July 23, 2012 at 4:13 pm
    [Hermann Haf] “can you guys recommend any other codec I can use ?”
    That depends on the system you are delivering to.
    How are you actually going to use this output?
    Walter Soyka
  • Hermann Haf
    July 23, 2012 at 4:54 pm
    Its for a pixel display on a building, same building as in this video: https://www.youtube.com/watch?v=u8sqI2HIIkI
    The output has to be AVI and 5×28 pixels.
  • Todd Kopriva
    July 23, 2012 at 6:55 pm
    See this post for some detail about output constraints:
    https://blogs.adobe.com/toddkopriva/2010/06/output-module-constraints-in-a.html
    In this thread, Tim Kurkoski goes into a lot more detail about the constraints for AVI files:
    https://forums.adobe.com/message/2973980
    product manager, professional video software
    After Effects team blog
    Premiere Pro team blog
  • Hermann Haf
    July 24, 2012 at 8:09 pm
    Thanks, this workaround posted by kelly_hanson at forums.adobe.com is the best way around this I guess 🙂
    It’s not ideal, but we’ve been using the process below to make it work. It adds a couple extra steps, but as of now, it’s the fastest way we’ve found to get around the issue.
    In After Effects:
    Render any comps smaller than 32×32 as an MOV. .mov files will render in sizes smaller than 32×32 without adding the black bars at the top & bottom
    Drag the rendered .mov files into Photoshop. Set yourself up an action to export the files back out of Photoshop as an uncompressed avi. Give it a function key (F3 or something for a tiny bit of added speed – especially if you are doing a LOT of files like we do) and it’ll export the file, with the original file name but in .avi format.
    Again, it’s not ideal – but that’s how we’ve been getting around it.
    Hope it helps!
