Small rectangular area not working when using chroma key.
I have what I assume is a very strnge problem, since I can’t find the same issue anywhere.
When I use either Sony Chroma Key or New Blue Chroma key, there is a small rectangular area not responding, near the center of the screen. It’s always in the same spot. It happens regardless of the videos being used. I cannot figure this out. Any help would be greatly appreciated.This image I included is an example. The monitor in the video is green screened and you can see that although it works fine most everywhere, there is a small section that is still green.
Thanks again,
Troy
