Activity › Forums › Apple Final Cut Pro Legacy › Small finder window when invoking import command
  • Small finder window when invoking import command
    Posted by David Eells on March 1, 2013 at 4:16 pm
    I’ve never had or heard of this problem before, but here goes.
    I’m working on a brand new Mac Pro running FCP 7.0.3 over OSX 10.8.2.
    Whenever I invoke the Import command, for instance to import a bunch of graphic into the Graphics bin, FCP opens a finder window (Choose a File: Final Cut Pro) and for some reason the Name column is always truncated, so I basically can’t read the names of the files. If I widen the column, the change isn’t persistent, so I have to resize the Name column constantly.
    Finder windows work as expected when opened from Finder.
    As always, thanks in advance.
    Bret Williams replied 13 years, 7 months ago 2 Members · 1 Reply
  • Bret Williams
    March 1, 2013 at 8:51 pm
    Try just using list view vs. column view. Unless you’re referring to the columns in list view, but I think youi’re referring to column view. I have the same column view issue with Mountain Lion.
