Activity Forums Maxon Cinema 4D Slowly Falling Letters of a word
  • Slowly Falling Letters of a word
    Posted by Robyn Rhodes on November 17, 2009 at 4:24 pm
    I’m trying to make words start falling in a slow motion fashion one letter at a time. Right now I have each letter as it’s own object. I’m using Gravity and a rigid body dynamics tag on each separate letter, and key framing the mass to make it start falling and I’m also giving them subtle gentle tumble some tumble. Is there a simpler way to do this with Mograph, where the text can remain editable and kernable etc? I need may need collisions in some cases. I also need an invisible floor catch the letters in one instance.
    Robyn
    Bruce Rudolph replied 16 years, 9 months ago 2 Members · 1 Reply
  • Bruce Rudolph
    November 18, 2009 at 3:53 am
    HI Robyn
    Your definetly doing it the hard way.
    Have a look at the file attached.
    I used a mograph text cloner for a start.
    Then shut off global gravity in edit/project settings.
    Then used a gravity force (object/gravity) with fall off to linear.
    The falloff cage is keyed and triggers the gravity as it runs through the letters. The axis direction is important.
    I used a turbulence force to move em a bit because they fall dead straight. (keyed to 0 at the end)
    You could do the same linear falloff setup with a random effector for the rotation only.
    Hope this helps.
    390_fallingletters.c4d.zip
