Activity Forums Apple Final Cut Pro Legacy Slowing down audio and video to then sync when sped up
  • Slowing down audio and video to then sync when sped up
    Posted by Mia Petry on September 24, 2011 at 12:46 pm
    Ok, so am very new to this, but what I did and trying to figure out is the following:
    I slowed down an audio track in FCP by 40% ie to 60% (in the Modify > Change Speed section) then I recorded the video with singing.
    Then I brought it all in and sped it up by 40% to 140% and brought in the original audio (which of course is at 100%), BUT it doesn’t sync up.
    I must be getting conversion rates wrong. Am currently trying to speed it up by 160% as the footage seems too slow for the audio.
    If anyone knows the conversion rates let me know. Have a feeling they are 1.25? Cheers!
    Many thanks!
    Mia Petry replied 14 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Mia Petry
    September 24, 2011 at 10:36 pm
    SOLVED, but if anyone is interested 165% did indeed work, ie adding the 40 plus a quarter on top did sync up with the original audio.
  • Andrew Rendell
    September 25, 2011 at 2:44 pm
    Well, logic would suggest that you’d need to speed up by 166.6666666666666666 (etc) %
    so 165% would be close enough (i.e., it would take a while before you’d notice it slipping)
  • Mia Petry
    September 26, 2011 at 8:35 am
    Hi Andrew, Cheers for that….so where am I going wrong…ie. what’s the calculation?
  • Jean-christophe Boulay
    September 26, 2011 at 3:59 pm
    You start with 100 apples. You take 40% of them away, you have 60 apples. You want 100 apples again. If you add 40%, that’s 40% of 60 apples, which is 24 apples. You want 40 apples over your 60 apples, which is 2/3, which is 66.66667%. After you slow down the footage, the reference frame changes with it.
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Mia Petry
    September 26, 2011 at 5:23 pm
    Many thanks!
    The ten year olds amongst this forum will be grateful that you used apples to explain this 🙂
    September 28, 2011 at 2:15 pm
    It’s how Ms. Diane taught me this and, to this day, I still visualize apples when working with fractions. No nagging intended. OK, maybe just a little. 🙂
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
  • Mia Petry
    September 28, 2011 at 8:32 pm
    Hehe, well thank you. I appreciate you taking the time to answer no matter how 🙂
