slow video in FCP, not matching audio
Hello folks. I’m editing a movie in FCP 6.0.1 on a Macbook Pro. The video has been imported from a Sony HD camcorder (1920×1080). Interestingly, the clips show as 2560×1080 when imported into FCP (using Log & Transfer). Not sure why that is, but when burned to DVD they look fine to me. Clips are imported using the Apple ProRes 422 encoder. This is our 2nd movie with this setup
We had been editing the movie fine, looked pretty good, but for some reason now the video clips seem to play “stuttered” (almost like in slow-motion). The audio plays fine but the video does not match, it’s like frames are being dropped. Possibly this is related to the “RT” tab at the top-left of the timeline (choices: Full Quality, Playback settings). We modified this and I think this is when the problem started. But no matter what we change it to we can’t get the video fixed. Something fundamental seems to have changed the clips because opening up an older project file (referencing same clips) I get the same weird effects.
One other thing – when opening the project file in FCP it states that some of the render files are missing so we need to either Reconnect or work Offline. I don’t know what caused this to happen and not sure if it’s related to the video issue. But one time when opening the project I selected “Reconnect” and then “Quit” and then played some clips from the timeline – no problem with the audio/video! But now it is broken and the above sequence does nothing.
Would greatly appreciate any help!
-Jason
