Activity › Forums › Adobe Premiere Pro › Slow to launch export
  • Slow to launch export
    Posted by David Braman on May 8, 2012 at 2:41 pm
    I’m trying to export media, but every time I click on export media it takes FOREVER to launch the dialog. And if I go to add it to the que its the same intolerable crawl to launch Encoder. The render times are fine. Is this normal? (hope not)
    David Braman replied 14 years, 4 months ago 2 Members · 6 Replies
  • Jeff Pulera
    May 8, 2012 at 8:17 pm
    Hi David,
    Are you using Matrox MXO2 hardware?
    Jeff Pulera
    Safe Harbor Computers
  • David Braman
    I am. Is that the problem?
  • Jeff Pulera
    May 8, 2012 at 8:20 pm
    Hi David,
    Here’s your easy fix, detailed in the Release Notes for your driver –
    If you find that switching the export format in the Export Settings dialog
    box sometimes takes a long time, such as when you switch from Microsoft
    AVI to MPEG2-DVD, rename the SurCodeWrapper.vca file on your system
    (for example, rename the file to SurCodeWrapper.vca.bak). This file is
    usually installed by Adobe Premiere Pro in the following folders:
    C:Program FilesAdobeAdobe Premiere Pro CS5MediaIOcodecs
    C:Program FilesAdobeAdobe Media Encoder CS5MediaIOcodecs
    Jeff Pulera
  • David Braman
    May 8, 2012 at 8:24 pm
    Thanks, I’ll give that a try
  • Jeff Pulera
    May 8, 2012 at 8:28 pm
    Hi David,
    What version of Premiere and Matrox drivers are you running? With CS5.5, you want to be updated to 5.5.2 and running latest Matrox 6.1.0.100 driver for best performance on the PC.
    Jeff Pulera
  • David Braman
    May 9, 2012 at 12:28 pm
    BINGO!!!
    Problem solved completely.Thank you..I will erect a shrine in your honor.
