Activity Forums Adobe After Effects Slow renders, After effects_CS5_OSX 10.6.5
  • Slow renders, After effects_CS5_OSX 10.6.5
    Posted by Ben Lindemuth on April 6, 2011 at 6:17 pm
    Hey there all,
    Tried searching to diagnose problem, was hoping someone could weigh in.
    My render’s have been going extremely slow lately. I am working on a documentary, doing additional editing and graphics. When I first started on this system, I did not notice any performance issues, but as we have moved forward, render times have slowly decreased, and as of late a few elements that I cue will not even begin to render out. I have another single core system at home that renders out twice to three times as fast.
    The only thing that I could think of is that we have been adding on additonal storage for extra media, however I’m not sure how that could affect AFX render times. Right now we have a 12TB Internal Raid as well as an external 4TB graid drive. OS is on an external 1tb Graid.
    Here are my system specs – MACPRO 2009 – Dual 2.26 – 8GB Ram – RADEON 4870_OSX 10.6.5_CS5
    I have used Tech Tool Pro to defrag and repair my os drive.
    Any Ideas?
    Apologies in advance if I’m missing something, or this is obvious.
    Ben Lindemuth replied 15 years, 5 months ago 2 Members · 2 Replies
  • Rich Kaelin
    April 6, 2011 at 11:57 pm
    I have been experiencing similar problems. At this moment I am doing a render, and I did several experiments for render times. I run dual quad (8 x 3.06GZ) with 12 GB RAM and raid arrays. When I turned multi-processing off, render times went up 4x, so I experimented and settled on 4 processors at 1.5 GB RAM each, which seemed to yield the best time. I have found that different effects utilize processors and RAM in different ways, so I have yet to settle on what settings are best.
    I will say that Macs do get bogged down after a while. A gentleman named Rafael gave me some advice on system maintenance a while back when FCP was crashing/bogging. It Helped a lot. It is a good idea to really “clean house” now and then. I think it is time for me to do it again. Here is the link to his post:
    https://forums.creativecow.net/readpost/8/1105933
    In my view, it is a good Idea to just clean out and even reload from scratch, OS and all, now and then. The type of work we do generates a lot of files and junk that gets hard to keep track of and get rid of. The average Mac user does not have these issues. Also, even though it is a Mac, we (or at least I) sometimes install stuff that will run in background and slow things down, and then I become unaware that they are there and I do not need them.
    I hope others post advice on this, I could use it, I am far from an expert, just speaking from my experiences. Also (and this is from experience as well) a failing hard drive, and sometimes they still work when they are on the way out, will really slow things down.
    Rich Kaelin
    Kaelin Motion Production Services
    https://kaelinmotion.com
    New York
  • Ben Lindemuth
    April 8, 2011 at 5:47 pm
    Thanks for the tips – I’ll check try to defrag, and rebuild my system.
    Very strange. I just did a test render of this linked project – and it took 10 minutes to render with multi processing disabled. And then I moved over to a cloned machine of mine – exactly the same setup – and the same exact render took 2 minutes.
    https://www.box.net/shared/njnlggyro2
    I think a fresh install is warranted.
