Activity Forums VEGAS Pro Slow Rendering
  • Slow Rendering
    Posted by Mike Hite on March 7, 2010 at 7:49 am
    I am trying out a trial version of sony vegas 9 pro
    It takes me 42 mins in pro to render NTSC DV Widescreen where as in platnium and hd version it took less than 15.
    What gives? Is pro supposed to be slower?
    How do I make pro run like it did on my other versions?
    I used platnium and hd versions on 100% defaults with 8 frame transitions, rendering NTSC DV Widescreen codec 100% of the time.
    *.wmv to *.avi NTSC DV Widescreen
    John Rofrano replied 16 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    March 7, 2010 at 5:00 pm
    They times should be about the same. Are you sure that you project properties and render properties are the same? Something doesn’t sound right.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Hite
    March 7, 2010 at 6:47 pm
    I’m not sure if this would matter, but I have noticed that the NTSC DV Widescreen is titles “= NTSC DV Widescreen” vs “NTSC DV Widescreen” on the HD and Platnium versions. Its also got something called 3-2-2-4 pulldown or something like that labeled 24p.
    Different codec maybe? I’m not sure to be honest, but I would love to get this issue fixed so pro runs just as fast.
  • John Rofrano
    March 7, 2010 at 9:23 pm
    Is your source 24p? If not, that might be your problem. If this is straight NTSC DV Widescreen then you should use 29.97 on your project, footage, and render options. Not 24p.
    ~jr
