Activity Forums Adobe After Effects Slow Render
  • Slow Render
    Posted by Matt Jurgemeyer on March 31, 2010 at 4:20 pm
    I’m not sure if I’m doing something wrong, but it’s taking over an hour to just render a 1:45 project.
    I’m not on the fastest machine in the world, but not the slowest either. I’m on a 2.66GHz, 4-core Imac with 8GB of RAM. In the settings, I chose to render multiple frames simultaneously at 2GB per process with leaving 2GB for other applications.
    When rendering, it says RAM: 6% used of 3.0GB.
    Am I missing something?
    Johnson Abercrombe replied 16 years, 5 months ago 4 Members · 6 Replies
  • Alperen T. ayhan
    March 31, 2010 at 4:44 pm
    there may be lot’s of things but
    1- do not use multiple frames simultaneously
    2- your project may contain lot’s of effects/layers/actions/presets etc.
    those make it harder to calculate.. Also 1:45 is quite long, so it may take an hour or over an hour.. This is normal, if you have so much layers or effects etc..
    Alperen T. AYHAN
    http://www.sinamasal.com
    Always cinema…
  • Matt Jurgemeyer
    March 31, 2010 at 4:58 pm
    I think I may have solved it. I have a background animation made up of a bunch of effects and actions applied to a fractal. I’m just going to save that layer out alone and bring it back in as video. I’m hoping that will speed everything up. Because my last minute and 45 second export was at 2 hours when i stopped the render.
  • Alperen T. ayhan
    March 31, 2010 at 5:39 pm
    ok, I hope you will have the success.. 🙂
    Alperen T. AYHAN
    Always cinema…
  • Todd Kopriva
    March 31, 2010 at 5:54 pm
    The idea of pre-rendering that complex layer sounds like a good idea.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Matt Jurgemeyer
    March 31, 2010 at 8:16 pm
    Thanks, it definitely helped.
    It was rendering in about 2 hours before. Now, it’s taking about 10 minutes.
  • Johnson Abercrombe
    April 1, 2010 at 6:57 am
    I just want to pitch in that this also helped me immensely. I had a lumina matte of a 6000×4000 canvas that had a fractal applied as the lumina matte…. Since i changed the levels to only see the high points i thought it woulden’t cost too much rendering time.. boy was I wrong!
