Activity Forums DaVinci Resolve Slow reaction time on timeline
  • Slow reaction time on timeline
    Posted by Ido Shor on June 17, 2020 at 11:22 am
    Hey,
    whenever I choose a clip on the timeline, either in order to trim it, or maybe change some values in position or a text layer,
    the reaction time of resolve is extremely slow (1-3secs).
    anybody else came across this problem?
    maybe even found a solution?
    I have a strong work-station so I don’t think it’s a hardware issue.
    besides, scrubbing or playback as no issue what so over.
    it’s only this lag in reaction when I try to move things around or do anything inside the timeline…
    thanks
    Dosho.
    Ido Shor replied 6 years, 3 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    June 17, 2020 at 12:17 pm
    Post your computer specs. Also: Resolution/framerate of your footage/timeline? What’s the format of your footage? What is your Resolve version?
  • Ido Shor
    June 17, 2020 at 12:33 pm
    right, sorry. (didn’t think it matters, but you are right)
    Timeline:
    1080*1920 (vertical) 25fps
    footage:
    4K,( but as I said, it happens also when I am just trying to move a text layer.)
    a combination of .MOV from a Blackmagic camera or iPhone, DPX sequences (from comps) and PNG sequences.
    computer specs:
    Intel(R? Core(TM) i7-9700K CPU @ 3.60GHz
    RAM: 64GB
    WIN10
    GPU: NVIDIA GeForce RTX 2080Ti
    tnx.
  • Tero Ahlfors
    June 17, 2020 at 12:55 pm
    You didn’t mention the Resolve version, but there were some issues with the timeline thumbnail generation causing some slow downs in some cases/formats. Try turning them off or changing it to heads and tails-only.
  • Ido Shor
    June 17, 2020 at 1:43 pm
    the build is 16.2.2.011
    I know about the tumbnail issue, I saw it in all the searches I did.
    but my issue is not with the zoom in/zoom out or playback.
    the problem I encounter is a delay in response when I try to move/trim etc. (as mentioned in the original post here)
    thanks anyways.
  • Michael Gissing
    June 18, 2020 at 5:32 am
    Have you tried to paste various files into another timeline and see if there is a particular file causing the timeline to have delay? With a combo of file types including image sequences plus possible frame rate differences, I would suspect there is a particular file that might be causing issues. Isolate one by one to see or it may be a combination of two file types that trigger the delay issues.
    And it’s always worth checking that your preferences are correctly set to match your GPU. I would set for CUDA and not let auto options decide for example.
  • Ido Shor
    June 18, 2020 at 7:20 am
    Tnx, will try that.
    Cheers
