Activity Forums VEGAS Pro SLOW Project Load — Did V14 change File I/O routines? Crash on opening Render dialog.
  • SLOW Project Load — Did V14 change File I/O routines? Crash on opening Render dialog.
    Posted by Red-rob Rothkopf on October 2, 2016 at 3:02 am
    I’m having two problems tonight with Vegas 14.
    PROBLEM #1 SLOW project load
    When loading my V14 project, it is taking *21 minutes* to load.
    0-3% instant
    @3% 11 minutes
    @ 11% 10 minutes –> Timeline populates then and project seems loaded.
    @ 3% my CPU was at 16% (Vegas using 15%), memory @ 28% and Disk I/O at 52 MB/s
    When loaded fully, CPU was at 36% (Vegas using 33%), memory @ 56%.
    I loaded a V10 version of this project into V10, and it loads instantly. (that version was from beginning of day — since then I’ve tweaked LOTS of edits, audio envelopes, and added media effects (mostly color correct).
    To assure it wasn’t my changes, I then loaded that same V10 version of the project into V14 as a control. Similar results to my newer V14 version of that project.
    0-6% 3 minutes
    6%-11%->100% 11 minutes
    Sat at 100% for another 11 minutes then the timeline loaded.
    Problem #2 – CRASH when selecting “Render-As” menu
    As soon as I choose -> , Vegas 14 crashes. (the dialog does come up shortly after the error reporting dialog appears.
    If I start with an empty project, add something small (e.g. 5-seconds solid color media generator), then Render-As dialog opens just fine.
    HELP!!!!!
    Red-rob Rothkopf replied 9 years, 11 months ago 2 Members · 3 Replies
  • László Kovács
    October 2, 2016 at 7:53 pm
    Do you use .mxf / .m2t files in your project accindentally?
    If yes, I think you should report to Magix.
    Best regards
    László Kovács
  • László Kovács
    October 2, 2016 at 7:54 pm
    Sorry, the link was not pasted:
    https://forums.creativecow.net/thread/24/1013982#1013982
    Best regards
    László Kovács
  • Red-rob Rothkopf
    October 3, 2016 at 4:20 am
    Not accidentally — yes, there is one .M2T file in the project (actually two, but the “control” (old version of the project) with Vegas-10 and Vegas-14 only has one of the .M2T files in it, the “SAT_LEFT1” clip.
