Activity Forums Adobe After Effects Slow Performance Question
  • Slow Performance Question
    Posted by Spooky on July 26, 2006 at 12:19 am
    Hello all,
    here is a quick question to see if others have this problem. Running AE 7 on OS X 10.4. When I have two keyframes, select both and right-click to select Easy Ease or any other property, I get the spiining beachball for about 10 seconds before I can do anything. Very very annoying and new with AE 7. Si this just bad programming and ther’s nothing I can do about it or am I alone in experiencing this and should dig deeper and find out hat might be causing it? Thanks!
    Tim Kurkoski replied 20 years, 2 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    July 26, 2006 at 5:01 pm
    Happens instantly for me, at least with a simple solid and changing opacity keyframes. What property are you setting the keyframes on? Try starting a new comp and seeing if a simple setup works, and if it does start looking for details that makes your comp more complex, and post back with more info.
