Activity › Forums › Media 100 › Slow Motion looks like draft quality?
  • Slow Motion looks like draft quality?
    Posted by Jaeson Koszarsky on April 19, 2007 at 3:38 pm
    I’m working on a project with media100HD11.5.1 in SD using media100i lossless settings.
    When I render a 50% slow-motion clip, it looks like it was rendered at a draft quality setting. The original clip is fine though.
    I tried changing the render compression setting to 300KB and got the same result.
    If I switch to a media100HD codec of 8-bit uncompressed, it appears as it should.
    Is there a way to correct this for Media100i codecs? If anyone has access to 11.6, does it work properly there?
    Jaeson K.
    Jaeson Koszarsky replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
