Activity › Forums › VEGAS Pro › Slow motion issue in Sony Vegas Pro 11
  • Slow motion issue in Sony Vegas Pro 11
    Posted by Martin Stanesby on October 19, 2013 at 5:48 pm
    Hi All,
    So, I’m struggling with achieving a real decent slow motion effect.
    Canon 6D DSLR shot in 50fps (IPB, best for editing).
    If i take the velocity below 25% it will start to look jittery. I have tried so many different combinations using either smart/force/disable resample; using project properties as either 50 or 25 fps; deinterlace method with interpolate; progressive……basically I’ve tried any combination (so I think).
    i want to get around a 5% slow motion effect….am I going to achieve this without Twixtor???
    I have tried rendering the footage at say 50%, then importing it back in and trying to slow it more from here. This was a little better but still not good enough.
    I have Boris Continuum Complete 7 using optical flow, but to be honest this is pretty poor and not worth the money, worse than Vegas on board velocity.
    Unless I’m doing something very wrong I am stuck. I appreciate any help.
    Martin
    Graham Bernard replied 12 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Graham Bernard
    October 19, 2013 at 6:30 pm
    I’m preeety sure you don’t have enough frames to do this. I use TWIXTOR a lot and can get down to 23% with it before it looks rubbish.
    Grazie
  • Steve Rhoden
    October 19, 2013 at 9:17 pm
    Graham is correct, you need your video files with high frame rates
    (far more than 50fps) to get really great slow mo effect past 25%.
    Twixtor is good, but you can only push it so far before the jiggles
    sets in.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Martin Stanesby
    October 19, 2013 at 11:38 pm
    Thanks Guys, It’s a case of getting as slow as I can before updating hardware I guess.
  • Graham Bernard
    October 20, 2013 at 7:07 am
    _______________________________________________________________
    [Martin Stanesby] ” It’s a case of getting as slow as I can before updating hardware I guess.”
    Pretty much….. And so that others reading this thread can have or take a considered view to slomo-ing I just completed 4 quick comparisons.
    OK, the clip is from my Canon PS SX50hs PAL 1920x1080p running at 23.976fps.
    Rendered at 25% Velocity with the Events set to Disabled Resample except B] which I used Smart Resample:
    A] – TWIXTOR – Used TWIXTOR default and reduced to 25% – Disable Resample
    TWIXTOR at 25%
    B] – Vegas Velocity Envelope – 25% & Smart Resample
    Vegas VeloEnvelop 25% Smart Resample
    C] – Vegas Velocity Envelope – 25% & Disable Resample
    Sony VeloEnvel 25% Disable resampling
    D] – Vegas Stretch Event – 25% & Disable Resample
    Vegas Stretch 25%
    So yes, undoubtedly going down to what you want, 5% (?), more frames per second would be better! I tried my best shot at this with Vegas, but there is just so much one can do when it comes to figuring and wrangling the s/w to cope. Maybe TWIXTOR support would like to butt in here and come up with an even better solution than my feeble attempts.
    Here’s the original Clip! LOL…! Blink and it’s gone . . . .
    Original clip
    Cheers
    Grazie
  • Steve Rhoden
    October 20, 2013 at 10:22 am
    Then Twixtor would be your best bet!
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Steve Rhoden
    October 22, 2013 at 9:18 am
    Or a Phantom Digital Cinema Camera….lol
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Thayalan Paramasawam
    October 27, 2013 at 6:50 am
    Hi Sir,
    Is this twixtor support SVP 11 and SVP 12
    Thank You
  • Graham Bernard
    October 27, 2013 at 9:25 am
    [Thayalan Paramasawam] “Is this twixtor support SVP 11 and SVP 12”
    Click here to check out the TWIXTOR site for the correct information.
    Cheers
    Grazie
