Activity › Forums › Panasonic Cameras › Slow mo and the HPX 500 and FCP
  • Slow mo and the HPX 500 and FCP
    Posted by Misha Manson-smith on September 4, 2008 at 11:42 am
    Hello
    I’m about to shoot a drama on the HPX 3000, but some sequences I want to over-crank, as it were, so I figured my best bet was to actually step down to the HPX 500, as, even though it’ll mean working at 720P, that way I can keep it all on the P2 cards and not get into shooting with the Varicam, as I believe getting useable slowmo footage off the Varicam involves a very expensive conversion process.
    My question is a) is this a good idea and b) will the 60P (or 50P) material I shoot on the 500 just turn itself into lovely slowmo footage in my 25P FCP sequence, or will I need to go through some hellish conversion process?
    Cheers
    Misha
    http://www.mercenaryfilms.co.uk
    Whitney Jean replied 14 years, 10 months ago 5 Members · 5 Replies
  • Shane Ross
    September 4, 2008 at 10:06 pm
    The slow motion option depends on the NLE you are using. FCP does the conversion internally…for free. And if you shoot on P2, you can even have the camera shoot slow motion internally, so when you import, it is already slow motion.
    Shane
  • Jay Shelton
    September 5, 2008 at 1:28 am
    Shane, would you mind expanding on how to shoot the slow mo internally? I just received my HPX500 and have not done this yet. It sounds like it would be a wonderful “shortcut”. Thanks in advance!
    Jeremey @ DI
  • Shane Ross
    September 5, 2008 at 5:27 am
    Well, in the HVX-200, you set the SCENE FILE>Frame Rate to 24Frame, then in the RECORDING SETUP>REC FORMAT you set to 720p60. Not sure if the 500 does that too.
    Shane
  • Steve Eisen
    September 6, 2008 at 2:52 am
    HPX-500
    Recording Setup 720p60
    Scene File/Operation Type Film Cam
    adjust your Frame Rate
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Whitney Jean
    November 26, 2011 at 1:24 am
    Is this also true with FCPX? I’ve been running into conversion issues with P2 content files. They are easy to import fromt he camera but not as mxf files.
    Also, does shooting in slow motion (as opposed to doing it in post) create a better look? or larger files?
    Thanks 🙂
