Activity Forums Adobe Premiere Pro Slow Mo a 4 second clip shot at 30fps to 8 seconds
  • Slow Mo a 4 second clip shot at 30fps to 8 seconds
    Posted by Adam Berch on July 5, 2019 at 12:51 am
    I want to make sure I am doing this the right way and this is the best way to do this.
    I was handed some footage.
    The main camera was shot in 30fps
    The second camera was shot in 60fps.
    I dropped the first clip, which was from the main camera, on a sequence and it asked me if I want to changed the settings to the clip settings? I clicked yes and the sequence changed to 30fps 1920 x 1080.
    It was a 4 second clip. I want to slo mo it. Here is what I did.
    1- I right clicked on the clip in the timeline.
    2- I hit Speed/Duration
    3- A pop up box came up.
    4- I changed the speed to 50% (it’s now 8 seconds)
    5- I then changed the interpolation to Optical Flow.
    5 – I rendered that clip o the timeline and played it back.
    6 – It looked great.
    Jon Doughtie replied 7 years, 2 months ago 2 Members · 1 Reply
  • Jon Doughtie
    July 5, 2019 at 10:42 am
    Yes, from the timeline in Premiere Pro, that’s how you do the slow-mo.
    As for changing the sequence to 1080/30, that depends upon what you wanted for your final product. If you want your finished work to be 1080/30, you’re all set.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
