Activity Forums Adobe Premiere Pro Slow encoding response
  • Slow encoding response
    Posted by Joanpablo Torres on January 19, 2012 at 11:26 pm
    I tracked down several No Response discussions, one primarily with a gentleman running CS4 but wanted to throw my hat into the ring.
    CS5.5
    Running Premiere Pro (same issue with Media Encoder)
    Windows 64 Bit 7 Pro
    i7 x980 CPU
    12G RAM
    All software up to date
    AVG anti-virus
    I get a Not Responding when trying to export or queue files then after any where from 60 seconds to two minutes Premiere/Encoder will finally respond.
    Occurs with SD and HD footage, with and without strenuous effects. Can’t seem to find any rhyme or reason.
    The same issue occurs when I try to change the encoding format. I get a Not Responding error in bot Premiere and Encoder than after a while it will finally respond.
    Any help would be appreciated.
    Joanpablo Torres replied 14 years, 2 months ago 2 Members · 2 Replies
  • Garry Douglass
    June 28, 2012 at 9:47 am
    Hi
    I’m running Premiere Pro CS5.5 & I have recently started to have the same problem when exporting my media.
    Were you able to fix this problem?
  • Joanpablo Torres
    June 28, 2012 at 1:51 pm
    nope never did and it’s still as annoying as ever.
