Activity Forums Adobe After Effects Slow Clock Speed on Dell 5820, Intel Xeon W-2175
  • Slow Clock Speed on Dell 5820, Intel Xeon W-2175
    Posted by Manish Choudhary on December 30, 2018 at 10:12 pm
    So I’ve purchased dell workstation 6 months ago and its working fine no issues, but since I’ve purchased that Workstation i saw processor is not working fine while rendering something.
    For some reasons processing speed has to be 4.3ghz while its using 1-2 cores in after effects because after effects use clock speed more that cores but its speed was 3.3-3.6 something so i how to fix that?
    Specs are
    Dell Precision tower 5820
    CPU- Xeon-W2175
    RAM-64GB
    Graphic Card – Quadro P5000
    Storage – Lacie 6big 24TB
    OS drive – Intel Enterprises Class SSD
    Cache Drive – NVMe SAMSUNG SM961
    Max Haller replied 7 years, 8 months ago 2 Members · 2 Replies
  • Manish Choudhary
    December 31, 2018 at 12:15 am
    i think problem with processor or other things that not letting boost system to the higher clock speed.
  • Max Haller
    January 2, 2019 at 4:40 pm
    You can check your power profile and check the min and max speed of your cpu, you might want to start there. Some power saving profiles will limit the max speed or stop it from boosting.
