Activity › Forums › Apple Final Cut Pro Legacy › Slow and jerky playback – 1920 x 1080
  • Slow and jerky playback – 1920 x 1080
    Posted by Jonny Cates on August 28, 2013 at 12:47 am
    I finally made the switch from standard to HD. I’m editing a 1920 x 1080 project, at 60i. When viewing my footage in the standard browser or canvas setting, this footage looks and plays back fine. But if I enlarge either of these windows to a much bigger size (or output a Quicktime) it doesn’t play back real smooth….sort of slow and a bit jerky. “This won’t look this way when I burn a disc will it?”
    “Could this be because I’m running just 2gb ram, or is this a VRAM issue?”
    ” I only have 256 mb VRAM and my graphics display is a NVIDEO GFORCE 9400, on an iMac intel, 3.06 Intel Core Duo.”
    Thanks…
    Jonny Cates
    Jonny Cates replied 13 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 28, 2013 at 2:07 am
    [Jonny Cates] “”Could this be because I’m running just 2gb ram, or is this a VRAM issue?””
    2GB of RAM for FCP editing HD? Yeah, that’s VERY low. 4GB minimum, but 8GB for comfort.
    [Jonny Cates] “” I only have 256 mb VRAM and my graphics display is a NVIDEO GFORCE 9400, on an iMac intel, 3.06 Intel Core Duo.””
    That is pretty darn low too. 512MB is recommended…but this should work. I think the biggest issue is the amount of RAM you have. Also…what drive is the footage stored on? Connected how?
    Shane
    Little Frog Post
  • Jonny Cates
    August 28, 2013 at 11:25 am
    Shane…
    I was actually wrong about the amount of memory I have. I do have 4gb – not 2. I was mixed up with another machine I have. But the rest of my info is correct.
    I assume this “slowness” would still be attributed to the lack of more ram, huh?
    Thanks….
    Jonny Cates
