Activity Forums VEGAS Pro Sloooow NeoHD Render
  • Sloooow NeoHD Render
    Posted by Dale Spetz on November 12, 2007 at 3:07 pm
    I am doing my first renders out of Vegas8 via NeoHD Codec v3.3.0 and the render time is painfully slow (30min project approximately 16 hrs!).
    I have Core 2 Duo (2.13ghz, 3.5ram). Dynamic Ram set at 0. Max threads set at 4. Quality set at “best”. NeoHD codec set at FilmScan1.
    It is a multilayered, somewhat complex project. Editing is done in HDV. Rendering is to HD (via NeoHD).
    Is my system just too wimpey for this work? Or, do I likely have something incorrect in the settings.
    Will a quad-core perform significantly better?
    Dale Spetz replied 18 years, 10 months ago 1 Member · 1 Reply
  • Dale Spetz
    November 19, 2007 at 2:53 pm
    Never mind. Pilot error, again!
    While I had my OS and source files on seperate drive, I had my scratch drive and render-destination drive as the same. This was fine for simple projects, but it caused a severe traffic problem for complex projects.
    Re-allocating drive functions sped up my render a mere 10x.
