Activity Forums Apple Final Cut Pro Legacy Slightly OT question for Elgato Turbo.264 HD users
  • Slightly OT question for Elgato Turbo.264 HD users
    Posted by Michael W. towe on October 29, 2009 at 10:09 pm
    I just picked up one of these and I am having some issues with it. I’m assuming that some of you may own it, and since Elgato isn’t answering my question, I figured I’d try here.
    When doing encodes with this device there is no way to correct the gamma for computer playback. I started using the TurboHD software initially and that didn’t work, I then did a couple encodes with it through Compressor with a gamma adjustment applied and that didn’t work either. It looks like once you set up Compressor to use the device it overrides the compressor settings.
    Have any of you found a way to make gamma corrections while using this thing?
    Mike
    Michael W. towe replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
