Activity › Forums › Apple Final Cut Pro Legacy › Slightly OT: portable hard drive with no moving parts
  • Slightly OT: portable hard drive with no moving parts
    Posted by Bob Roberts on October 5, 2006 at 7:34 pm
    I’m in the market for a small portable firewire-400 hard drive (…so I can take work home to my iMac). I’d like something with no moving parts.
    Can anyone share their experience and/or suggestions?
    Thanks in advance.
    Bret Williams replied 19 years, 12 months ago 5 Members · 5 Replies
  • Jeff Carpenter
    October 5, 2006 at 8:27 pm
    Well, all hard drives have moving parts. They spin in circles…7,200 times per minute.
    But that aside, they can get the job done. Pretty much any firewire hard drive will do the trick. They will require their own power source, but if you’re using an iMac I assume you’ll be near an electrical outlet.
    Firewire drives are reasonably safe, but you should only use them for media that is still on tape and can be re-captured. So any graphics, audio files, or Final Cut project files can be transferred home on the drive but should be copied off of it to the iMac when you get home.
    In the last 4 years I’ve only had 1 of my 5 firewire drives fail 1 time…that’s a very good percentage, but it’s not perefct. As long as you follow that rule any hard drive failure means you’ll just have to re-capture footage and not re-do work.
  • David Roth weiss
    October 5, 2006 at 8:29 pm
    Bob,
    They all have internal moving parts. Perhaps your best bet is something like the Lacie “All Terrain” mobile hard drives, which you can see at https://www.lacie.com/products/product.htm?pid=10722
    DRW
  • Bob Roberts
    October 5, 2006 at 11:43 pm
    Bummer, I thought stuff like the G-Drive Mini was all solid state…like an iPod or P2. I guess not.
  • Ron James
    October 6, 2006 at 12:33 am
    Only the small (2, 4 GB) iPods have flash drives. My iPod Video has a small hard drive. You can actually feel it whirring away at times.
    God I love my iPod.
  • Bret Williams
    October 6, 2006 at 5:14 am
    So why not use an iPod? It doesn’t require it’s own power source which is nice.
