Activity Forums Apple Final Cut Pro Legacy Slightly Jerky Scrolling Photos Video—How to Output it to Play Smoothly?
  • Slightly Jerky Scrolling Photos Video—How to Output it to Play Smoothly?
    Posted by Daniel Monskey on November 27, 2014 at 5:02 am
    I have a 17 second sequence of scrolling (R-L) photos that play with a slight infrequent jerkiness.
    I am using FCP 7, on a MacPro with 2 x 2.8 Quad-Core Intel processors; 8 GB 800MHz memory; Lion 10.7.5. I am storing data on a Wiebetech Raid external drive system connected with a eSata cable.
    I have output it using Compressor in Quicktime with Codecs: Apple ProRea 422 (HQ) Linear PCM
    I have also added it to an After Effects project and output it with the same settings (Apple ProRes 422 (HQ) and I still have the same problem.
    In both cases the .MOV video is about 456 MB, so not very large at all to slow things down.
    What do I need to look at to get a smooth flowing sequence of scrolling photos?
    Dan
    Daniel Monskey replied 11 years, 9 months ago 1 Member · 1 Reply
  • Daniel Monskey
    December 1, 2014 at 10:27 pm
    Thanks Dave. I’ve never heard of this judder.
    What I get from your suggestion is I should try something like this:
    slow down the rate of the scrolling photo sequence, output it and then speed it back up in a new timeline so I maintain the same time length—vis versa—or something like that.
    I tried creating it in Adobe After Effects too and I still have the same problem.
    I can test it with an existing sequence or .MOV file by speeding/slowing it down.
    Dan
