Activity Forums Apple Final Cut Pro slight white flickering between some clips when film is shown with projector
  • slight white flickering between some clips when film is shown with projector
    Posted by Jack Niedenthal on October 11, 2014 at 9:46 pm
    I did a film using FCPX 10.1.3 on an iMac using the latest Mavericks update. The film is 1920×1080 24 fps progressive.
    When I view the outputted .mov file on my computer, whether viewing the H264 version or the ProRes422 version, the film looks fine. The same is true if I play the film from my timeline in FCPX.
    When I show the film hooked up from my laptop computer (Macbook Air) to the BENQ SH915 projector using either the H264 or the ProRes422 version, or if I use a BluRay disc, however, there are certain scenes where when going from clip to clip I get a slight white “flicker” between the clips (there are no transitions, just hard cuts). Maybe others wouldn’t notice, but I do, and not all clips do this…
    Is this flicker caused by the projector (is there a setting I should be looking for) or is it caused by something on the FCPX timeline that should be done to the clips?
    Would re-rendering the entire project help fix this (and how would I do this)?
    Any other suggestions. Many thanks in advance.
    Jack Niedenthal
    Microwave Films of the Marshall Islands
    http://www.microwavefilms.org
    https://www.microwavefilms.org/Crickets.html
    iMac i7 using Mavericks 10.9.x, HPX 170 using only one 64GB card
    I live on an island in the middle of the Pacific, YOU are my only resource.
    Jack Niedenthal replied 11 years, 11 months ago 2 Members · 2 Replies
  • Bret Williams
    October 12, 2014 at 1:18 am
    Sounds like your projector can’t keep up with the change in contrast. Are all your values broadcast safe or are your whites at a hearty 120ire? I’ve seen some monitors do wacky things when cutting bright stuff.
  • Jack Niedenthal
    October 12, 2014 at 10:29 am
    Actually, what it turned out to be was the econo mode setting on the projector. When I switched to the normal mode for projection it looked fine.
    Jack Niedenthal
    https://www.microwavefilms.org/Jilel.html
