Activity Forums AJA Video Systems slight io problem
  • slight io problem
    Posted by Rick Neely on January 26, 2008 at 7:42 pm
    Having a problem with an io,
    running a dual 2.3 power pc mac with FCP 2 studio. We’re having trouble with realtime previews on an external monitor. Settings are configured the best I think–
    – IO is set on output settings (mirror on desktop enabled, same problem when disabled also)
    – external video is set to all frames
    – sequence is fully rendered
    – have trashed preferences and rebooted, still no luck.
    The monitor does display a freeze frame of the time marker point when the sequence isn’t playing real time and when I drag the time marker the image DOES follow in the monitor. It just won’t play sequences in real time.
    Any suggestions would be great. Thanks!
    Rick
    Gary Adcock replied 18 years, 8 months ago 2 Members · 1 Reply
  • Gary Adcock
    January 26, 2008 at 7:55 pm
    [Rick Neely] “The monitor does display a freeze frame of the time marker point when the sequence isn’t playing real time and when I drag the time marker the image DOES follow in the monitor. It just won’t play sequences in real time. “
    then your timeline does not match your output.
    reset the easy setup and try again,
    do not let fcp choose the settings for the timeline- it can set it to frame sizes that do not output correctly
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
