Activity › Forums › Apple Final Cut Pro Legacy › Slight color (and maybe gamma) shift on playback vs. paused
  • Slight color (and maybe gamma) shift on playback vs. paused
    Posted by Benjamin Reichman on October 21, 2010 at 3:54 pm
    I’ve noticed that when I play back XDCAM EX 1080i60 clips in Final Cut Pro, they are slightly darker and cooler while playing, only to appear brighter and warmer when playback stops (when I’m just looking at still frames). HDV 1080i60 clips play back without this issue, but when I use the mouse to extend HDV clips in the Timeline, the same color/brightness shift happens while I’m dragging.
    I have a Mac Pro running 10.6.4 and Final Cut 7.0.2. All footage is on a G-Speed eS RAID, set to RAID 5.
    Is this a graphics card issue? Here’s the full information from System Profiler:
    NVIDIA GeForce 8800 GT:
    Chipset Model: NVIDIA GeForce 8800 GT
    Type: GPU
    Bus: PCIe
    Slot: Slot-1
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x0602
    Revision ID: 0x00a2
    ROM Revision: 3233
    Displays:
    Display Connector:
    Status: No Display Connected
    Cinema HD:
    Resolution: 2560 x 1600
    Pixel Depth: 32-Bit Color (ARGB8888)
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Rotation: Supported
    Benjamin Reichman replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
