Activity Forums Adobe Premiere Pro Sliding a clip 1/2 frame.
  • Sliding a clip 1/2 frame.
    Posted by David Distinti on February 8, 2010 at 1:52 pm
    I had cleaned up some bad audio from a .avi video clip in Sony Sound Forge then went to place it back in my Premier CS4 timeline. I can’t get the .wav audio file to perfectly align with the prexisting clip’s audio. I can only get the audio clip to either be a frame ahead or behind. Is there a way to literally slide the audio clip a 1/2 frame? The sequence is in 24p and I turned snapping off. Any thoughts?
    Dave
    James Williams replied 11 years, 7 months ago 4 Members · 4 Replies
  • Jeff Pulera
    February 8, 2010 at 6:05 pm
    Hi David,
    Not in front of Premiere right now to look, but basically there is an arrow at the top right corner of Sequence window, click that and you will get option to display audio frames or units (something like that). It will change timeline ruler to audio samples rather than video frames and then audio can be moved in very small increments (audio resolution) rather than frames (zoom in for control!).
    After adjusting audio, you can change back to frames display. I often use this to sync audio between multiple cameras when waveform is half a frame off. Unlink video/audio first so you can move audio clip independently.
    Jeff Pulera
    Safe Harbor Computers
  • David Distinti
    February 8, 2010 at 7:48 pm
    I’ll check it out. Thanks Jeff!
    Dave
  • Todd Schmidt
    November 14, 2011 at 10:08 pm
    OMG….and old thread but this just saved my but! Thanks!
  • James Williams
    January 31, 2015 at 10:37 am
    Created an account to say thank you very much for this tip. Really helped me out.
