Activity Forums Apple Final Cut Pro Legacy Slideshow Compression
  • Slideshow Compression
    Posted by Darrin on September 9, 2005 at 4:15 pm
    I’ve built a slideshow using JPEG images and some text in FCP, and they are looking “scratchy” or not as clean and crisp when in iPhoto…..is there a specific setting in compressor or QT conversion that will bring them back to look like they did originally when I transfered them from the camera..?
    Thanks for your time….
    Darrin
    Matthew Brunn replied 20 years, 12 months ago 2 Members · 1 Reply
  • Matthew Brunn
    September 9, 2005 at 4:34 pm
    They will never look as high res as in iPhoto. Video has much less resolution, always, plus less color range and less dpi. Are you looking at this on an interlace CRT monitor? What resolution is the project in, HD,SD,DV? If you wanted to do a slide show with high res look at Powerpoint(yuck!) or Keynote from Apple.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
